Message 11 of 13
Re: thatRe: Very slow speeds most of the time for past 2 months - Help!
Ahhh I see thank you.
Sage
Message 12 of 13
Could you humour me and see if temporarily disconnecting your Sonos system makes any difference.
Message 13 of 13
Thanks for your help. An offer came up for Sky that worked out cheaper than BT.
Now with them with their Sky Q router and it's fixed the issue. Must have been the BT Hub which is what I suspected.
Interestingly, I now get 29mb down whereas I only got 19mb max (when working) on BT.
It's rock solid too. Wifi range is a lot poorer on the Sky Router however.
