adam_t
Message 1 of 6
Very slow sync speed - Fibre 1
Noticed my broadband download speed had fallen substantially.  My expected range per BT is 21Mb-39Mb (17Mb guaranteed) (DSL Checker 23.6-41.3) and had previously been getting in the low 30s.  Ran the BT online speed checker and diagnosis, chatted online and engineer visit recommended.  When the engineer came he took about 5 mins to point of that my downstream sync speed was set at 15.00Mb and that he would raise another fault to understand why.  Haven't heard anything since although I understand it's not a good time.
Router has been on and running for ages without restarts and the figure of 15.00 seems suspiciously precise.
Any ideas what could be causing this?
5 REPLIES 5
imjolly
Message 2 of 6
Re: Very slow sync speed - Fibre 1
can you post hub stats  if hh6 then advanced settings then technical log information  if hh5 then troubleshooting then helpdesk
try quiet line test  dial 17070 option 2  should be silent and best with corded phone
adam_t
Message 3 of 6
There is a very faint hum on the QL test
pippincp
Message 4 of 6
If the hum is with a corded phone then report a noisy line. You sure it was an Openreach engineer and not one of those Qube ones?
imjolly
Message 5 of 6
According to router stats connection time is only 16hrs was that due to router dropping connection or manual reset
can you enter your phone number and post results.
https://www.dslchecker.bt.com/
adam_t
Message 6 of 6
Sure - it may have been recycled to run a test.  But in general it is never rebooted and slow speeds have persisted for months.  It was an Openreach engineer.
