Message 1 of 14
Very slow upload speed
My upload speed  is almost 0.  BT said there was nothing they could do, there might me some work going on or others could be uploading a lot of content at the same time.  It was fine last night but has been like this for over 5 hours today since 8:30 approx.
Download speed varies between 60 - 72 Mbps
Upload speed has varied between 0.04 and 0.1 Mbps
I used the BT wholesale speed tester.
Any suggestions please? Thanks.
13 REPLIES 13
Message 2 of 14
Re: Very slow upload speed
post stats from your hub  if hh6 then advanced settings then technical log information
enter your phone number and post results  remember delete number but leave exchange and cab  https://www.btwholesale.com/includes/adsl/main.html
Message 3 of 14
Expert
Message 4 of 14
@peteathompson out of interest which browser did you use to get the speed test results? Some browsers behave oddly with the speed tester.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 5 of 14
On my desktop I used IE as Chrome complained about needing flash.
I also used Speedtest.net on the PC and also from my phone.
Same results on all tests.
PC is wired network, mobile is Wifi (obviously)
Expert
Message 6 of 14
@peteathompson
Thanks from the DSL Checker pic you should have no issues.
What sort of socket do you have?
A, B, C, DA, B, C, Dor does it look like thisthis
Do you have a phone you can plug in and test for any noise?  I can explain how shortly.
Kind Regards
CJT80
Message 7 of 14
connection looks good with max 80/20mb connection
can you run btspeedtester and when first test completes can you run diagnostic test and post results  must be done with wired conenction and preferably with IE/Edge  http://www.speedtest.btwholesale.com/
Message 8 of 14
It's the one in the photo.
No noise on phone line.
Expert
Message 9 of 14
@peteathompson excellent, lets work with @imjolly's suggestion now Smiley Happy
Kind Regards
CJT80
Message 10 of 14
