Message 1 of 2
WAN Cable
Hello,
my WAN cable connecting my router to the white modem box is broken and I need to buy a new one, I’ve seen lots of different CAT ones is there a specific one I need? I’m currently on Fibre 500 package. Thanks!
1 REPLY 1
Message 2 of 2
Re: WAN Cable
Cat 5e or Cat 6 will do.  (I doubt you can still get it, but if you can avoid Cat 5.  It can only handle 100Mb/s)
