Newbie
Message 1 of 7
WIFI speeds
Hi all. We recently moved to a new property that has Fibre so we upgraded our BT account to get 300meg with a guarantee of 150meg minimum. Are those numbers achievable on WIFI and at a stable speed? I've done numerous tests online  and we still only get an average of 35meg download even if the upload is upto 50+ now. Unfortunately the router is under the stairs so a wired connection appears out of the question. If I cant get the promised speeds on WiFi then there's no point paying for Fibre. Hopefully someone can help.
Thanks.
6 REPLIES 6
Message 2 of 7
Re: WIFI speeds
No ISP guarantees wifi speed, there are too many variables to affect the signal. Why not move the router to a better location, either run an Ethernet cable or use powerline adaptors between the ONT and router.
Newbie
Message 3 of 7
Re: WIFI speeds
We were told that the router had a specific port as its Fibre. Is that not true?
Message 4 of 7
Re: WIFI speeds
I have no idea what you mean by that.
Newbie
Message 5 of 7
Re: WIFI speeds
I cant move the router as the WAN port is under the stairs and I cant run any cables to anywhere else as its a rented house.
Message 6 of 7
Re: WIFI speeds
You could use powerline adaptors to connect the ONT to hub. Something like these but you don't need to use BT ones.
https://shop.bt.com/products/bt-broadband-extender-flex-1000-kit-080219-BB4X.html
Newbie
Message 7 of 7
Re: WIFI speeds
Haha set just arrived with the BT TV hub.
Hopefully it will sort out the poor speed to the PS4.
Thanks for your advice.
