Well that's what the email from BT said. Current contract is 50 Mbps and apprently 'within 4 weeks' I would be getting 67 Mbps. Well the 4 weeks AND 2 week speed adjustment period are up and guess what - things have got worse. Recent latency / upload/download speeds have been as follows
16/5.9/5.2 - 19 43.7/4.8 - 17/43.4/18.5 - 16/45 /19.1 - 18/27/17.6
PLUS countless drops / loss of iunternet. Nothing has changed my end and I've done all the usual chaecks (pointless though they are but BT insist you do them).
I've been with BT for longer than I can remember and put up with the odd blip in service, plus having the hassle of haggling for a new deal every year or so, but once I get all my contract renewal dates aligned (landline/broadband/mobile) I really need to look for another supplier.
Shocking service.
Solved! Go to Solution.
Enter your number HERE and post the result. Remove phone no first.
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate(Mbps) | Downstream Handback Threshold(Mbps) | WBC FTTC Availability Date | WBC SOGEA Availability Date | Left in Jumper |
High | Low | High | Low |
VDSL Range A (Clean) | 80 | 63.1 | 20 | 19 | 57.2 | Available | -- | -- | |
VDSL Range B (Impacted) | 80 | 58.6 | 20 | 19 | 49.8 | Available | -- | -- | |
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate(Mbps) | Downstream Range(Mbps) | WBC FTTP Availability Date | |||||
FTTP on Demand | 330 | 30 | -- | Available | -- | -- | |||
ADSL Products | Downstream Line Rate(Mbps) | Upstream Line Rate(Mbps) | Downstream Range(Mbps) | Availability Date | Left in Jumper | ||||
WBC ADSL 2+ | Up to 8 | -- | 5.5 to 12.5 | Available | -- | Yes | |||
WBC ADSL 2+ Annex M | Up to 8 | Up to 1 | 5.5 to 12.5 | Available | -- | Yes | |||
ADSL Max | Up to 5.5 | -- | 4.5 to 8 | Available | -- | -- | |||
WBC Fixed Rate | 2 | -- | -- | Available | -- | Yes | |||
Fixed Rate | 2 | -- | -- | Available | -- | -- | |||
Observed Speeds | VDSL | ||||||||
Max Observed Downstream Speed (Mbps) | 60.26 | ||||||||
Max Upstream Observed Speed (Mbps) | 20 | ||||||||
Observed Date | 2019-03-30 | ||||||||
Other Offerings | Availability Date | ||||||||
VDSL Multicast | -- | -- | -- | Available | -- | -- | |||
ADSL Multicast | -- | -- | -- | Available | -- | -- | |||
Premise environment | Status | ||||||||
Bridge Tap | N | ||||||||
VRI | N | ||||||||
NTEFaceplate | N | ||||||||
Last Test Date | 21-03-2019 |
from that you had 60mb connection few days ago can you post hub stats
if hh6 then advanced settings then technical log information
if hh5 then troubleshooting then helpdesk
any line noise try dial 17070 option 2 should be silent and best with corded phone
I saw that, but little use if it's never avaialble when I'm using the PC - as speedcheck stats show.
Did the 17070 Opt 2 and no line noise.
HH 5 stats
1. Product name: | BT Home Hub |
2. Serial number: | +068343+NQ42225350 |
3. Firmware version: | Software version 4.7.5.1.83.8.264 (Type A) Last updated 02/03/19 |
4. Board version: | BT Hub 5A |
5. DSL uptime: | 0 days, 08:26:22 |
6. Data rate: | 20000 / 64093 |
7. Maximum data rate: | 20914 / 60653 |
8. Noise margin: | 6.1 / 5.0 |
9. Line attenuation: | 15.2 / 15.7 |
10. Signal attenuation: | 15.1 / 15.7 |
11. Data sent/received: | 73.9 MB / 333.7 MB |
12. Broadband username: | bthomehub@btbroadband.com |
13. BT Wi-fi: | Yes |
14. 2.4 GHz Wireless network/SSID: | BTHub5-GXQ3 |
15. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 144 Mb/s)) |
16. 2.4 GHz Wireless security: | WPA2 |
17. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
18. 5 GHz Wireless network/SSID: | BTHub5-GXQ3_5Ghz |
19. 5 GHz Wireless connections: | Enabled (802.11 a/n/ac (up to 1300 Mb/s)) |
20. 5 GHz Wireless security: | WPA2 |
21. 5 GHz Wireless channel: | Automatic (Smart Wireless) |
22. Firewall: | Default |
23. MAC Address: | 40:f2:01:47:11:5e |
24. Modulation: | G.993.2 Annex B |
25. Software variant: | AA |
26. Boot loader: | 1.0.0 |
Your uptime is only 8 hrs. Is this due to a manual restart?
With a connection speed of 64Mbps.
As regarsds manual start - not today, but as per my original post connection dropping multiple times so that may be the cause - I don't know, I'm not a techie.
As for telling me I'm getting high speeds, there must be lies, damn lies and BT statistics because having used the same speed checker multiple times for consistency I've also tried others, and they're all telling me speeds are well below what should be expected. Check just before this reply came in at 23.7 / 4.55.
In my experience it's always a nightmare trying to speak to someone at BT and when you do they it's even harder to get them actually listen rather than follow their script (I know there's a reason for checklists and sequence, but when you've done it umpteen times and nothing changes then surely enough is enough). I guess I'll have to bite the bullet and try - again!
there is no guarantee on download speed - from any ISP
run btspeedtester and then diagnostic test and post results must be with ethernet connection not wifi http://www.speedtest.btwholesale.com/
you can also try speedtest.net as well
I appreciate there are no guarantees and I would have been happy to have kept the previous speeds of high 40's low50's but this is just useless.
BT checker stats at least confirm I'm not losing my marbles and that results are - well think of a word!
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
Download Speed (Mbps): 25.20
Upload Speed (Mbps) : 4.44
Ping Latency (ms): 40
Download Speed | |
3.36 Mbps |
0 Mbps | 62.04 Mbps |
Download speedachieved during the test was - 3.36 Mbps |
Upload Speed | |
4.32 Mbps |
0 Mbps | 20 Mbps |
Upload speed achieved during the test was - 4.32Mbps |
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
