sgreaves87
Newbie
Message 1 of 3
Website says i can't get infinity but my area is enabled.
So i live 200 yards from my exchange and my local cabinet that im supplied by is 30 yards away. My area is enabled for fibre optic but when i try and order it says i cant have it.
Using the wholesale checker i get this which says i can get fibre optic
---Image Removed---
But then when i try and order i get this
Anyone with any idea why it is ? is it just my line and could it be changed to accomodate infinity ?
2 REPLIES 2
Ratty2012
Recognised Expert
Message 2 of 3
Re: Website says i can't get infinity but my area is enabled.
First off you need to edit your phone number from the attached snapshot, second the checker shows that you can't get Infinity. Your local exchange maybe Infinity enabled, but the cabinet that your phone line is connected to is not.
Distinguished Guru
Message 3 of 3
Hi and welcome to the forum
Have you checked if any of your emediate neigbours can get infinity? As Ratty says just because the local exchange is enabled it looks by your results you can not get it as yet.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
