dikul
Message 1 of 4
Well done to Openreach and something new learned
After a long period of general slowdown on my Inifity 2 line and the usual rebooting of the router and India telling me that my building work/ trees and/or internal wiring must be at fault.  We have had no building work and no trees any where near the front of our property.
We eventually were vvisited by a special faults investigator, who found that when we had infinity installed that the wiring block in the box where the external wiring terminal ate just outside our front door was a screw terminal type and that "Inifinty" should never have any screw connections in the circuit.  Block changed to gel type and speed back up to 70 Mbps from 40-45.
well done that man.
3 REPLIES 3
Message 2 of 4
Re: Well done to Openreach and something new learned
@dikul
You can provide feedback to Openreach on this form.
https://www.formwize.com/run/survey3.cfm?idx=505d040e0a0e0c
dikul
Message 3 of 4
Thanks Keith, will done.
Message 4 of 4
All feedback does go back to their manager, and then onto the person concerned, and is appreciated.
