Message 11 of 16
Re: What is this box please ?
FYI , if no ONT has ever been previously fitted the checker states something along the lines of
‘WBC FTTP available, a new ONT may be ordered’ , if the address is recorded as a previous OR FTTP service existed , its something like ‘ONT exists with no active service’
Message 12 of 16
Re: Moving from Jurassic Cuckoo Fibre to EE.
You would be better posting on the  EE forum.
https://community.ee.co.uk/
Message 13 of 16
Message 14 of 16
It seems FTTP is available, single stage , overhead , no anticipated issues , so no previous Openreach FTTP installation ,  if FTTP ordered , the same pole and fixing at the house will (almost certainly ) will be used , duplicating the copper wire route , however the ONT  doesn’t need to be where the copper pair master socket is , it can be where you would like it , within reason .
https://www.openreach.com/help-and-support/full-fibre-broadband-installation-checklist
Message 15 of 16
That's Brilliant, so in effect Open Reach would replace the overhead copper pair from the pole to the property with fibre cable and install a proper ont where I want it, leaving the Jurasic Fibre install in place.
Many thanks for your excellent help.
Message 16 of 16
I did and got no replies but on here I've had several very helpful replies, it seems the BT forum members  are more tech savy than the EE forum members.
