Sage
Sage
Message 11 of 15
Re: When can I get fibre?
You cannot place an order until the checker says the service is live and accepting orders. You can however register an interest via the Openreach site and may be emailed when the service is live.
All you can keep doing ATM is keep checking. Not helpful I know but that's the way it is.
Message 12 of 15
That's right.
Until the work is started it won't be known if there are blocked ducts, issues getting power, resident complaints about the new cabinet, wayleaves needed etc.
sarfraz909
Newbie
Message 13 of 15
Thank you pippincp and Webby for your participation and ideas in this conversation.
Sage
Sage
Message 14 of 15
@sarfraz909 You're welcome. Please come back and let us know when you do eventually get connected.
sarfraz909
Newbie
Message 15 of 15
Sure, I'll definitely do that Man Happy unless it happens so far away in the future that I just forget about this particular post by then Man Frustrated.
