Message 1 of 12
When will Aylesbury Cab 98 be available for Infinity?
When will Aylesbury Cabinet 98 be available for Infinity?
An infinity box has been installed for a year now, and according to engineers (working on the cabinet) it is ready but has simply not been handed over by Openreach.
Is this a simple admin oversight?  Can someone get this moving as the existing speeds we get are terrible.
All I can get from BT Sales is it will be ready in a couple of months!  Given they have been saying this for the last year, it is getting tedious receiving the continual lies.
Can anyone find out why this is so badly delayed?
Dave
11 REPLIES 11
Message 2 of 12
Re: When will Aylesbury Cab 98 be available for Infinity?
this is a customer help customer forum and there is no link from here to openreach who will have the information you are looking for
write to openreach  https://www.formwize.com/run/survey3.cfm?id=7214&embed
if you get auto reply then send again until you get reply from a person
as an aside there is a fibre cab in my area for over 2 years and still not active
Message 3 of 12
Thanks imjolly,  I will try that.
Message 4 of 12
It's a BDUK cabinet. Try your local council and/or BDUK scheme. You're more likely to get an answer from them than you are Openreach.
BT Expert
Message 5 of 12
The Bucks & Herts (ConnectedCounties) BDUK/SEP scheme can be contacted via info@connectedcounties.org
They will needs your landline number and full address to check.
I see from the Openreach Where and When checker that it's at the connected stage.
Message 6 of 12
Message 7 of 12
Those dates are just placeholders. The OP knows it should have gone live a while ago, it's been in situ for over a year 😉
Message 8 of 12
I know, but that website is very good for finding out pretty much anything about exchanges. 🙂
Message 9 of 12
It's not that useful at the moment. The last time it was updated with Openreach data was May 5th, so it's almost 2 months out of date.
Message 10 of 12
No, it was last updated on the 22nd of June if you look on the left hand side of the website.
