Midgetgem1973
Message 1 of 2
Which Router?
I'm currently using the home hub 5, not sure if it's the hub but the past week or 2 streaming is becoming unbearable with it being very blocky, i stream on my ipad 4 which is connected at 5ghz, speediest are normally between 65mb - 73mb on my ipad wirelessly. So if I wanted to get another router it would have to have a modem built in as I don't have the openreach modem. It's only gotten like this since all the bad weather.
1 REPLY 1
Message 2 of 2
Re: Which Router?
It would need to be a VDSL modem/router or else you would need to get an Openreach modem which you could then use to connect any router.
