B13blues
Message 1 of 9
Why are openreach
Still using Kelly communications? Every time one of their employees enters our block of flats something goes wrong. This time I'm the unlucky recipient of their shoddy rushed work. Another flat gets connected up and I lose my phone and the router loses connection 2 or 3 times a day. Engineer booked and hopefully here next Thursday, we'll see. Last time it was a wire that had been left hanging so was shorting, wouldn't mind betting it's similar again. Rant over grrr.
8 REPLIES 8
Moderator
Moderator
Message 2 of 9
Re: Why are openreach
Hi @B13blues
Thanks for your post and welcome back!
Sorry you're having problems with your services.  Who is your service provider?  If your services are with BT Consumer we'll need to report this to Openreach to get this sorted.  Post back and let me know please.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
B13blues
Message 3 of 9
It is BT yes there is supposed to be an engineer visiting next Thursday so I don't think we can do much more until then. So frustrating it was me that recommended BT to the new resident and then this happens during his connection.
Moderator
Moderator
Message 4 of 9
@B13blues  I'm pleased to see an engineer visit has been arranged.  I can't apologise enough that you've been disconnected during their install Smiley Sad
Please keep us posted how things from go with the engineer's visit.
Cheers,
Robbie
Kudos”Kudos”
B13blues
Message 5 of 9
Ok will do thanks
Starwire
Message 6 of 9
You think Kelly’s are bad now you should’ve seen them a few years back.
Openreach will continue to use them because as the saying goes, ‘you don’t want to put all your eggs in one basket’.
B13blues
Message 7 of 9
Well I presume it still pays them even though openreach have to tidy up the mess they leave. Basic mistakes they're making purely through rushing to get to the next job.
B13blues
Message 8 of 9
Update. All sorted and a couple of days earlier than expected thanks to engineer Gemma at Openreach. Kelly Communications man had got his 2's and 5's mixed up. Thanks all this is now solved.
B13blues
Message 9 of 9
Sorry just to add she even got me my 80/20 connection back after Kelly Communications had visited my connection was down to 60/20. Really pleased with how this fault has been dealt with. Cheers all.
