abathingape
Message 21 of 45
Re: Why does my Line Speed Drop?
@gg30340 @john46
Just tried a restart of the modem.
My sync is now 50142 / 9997 kbps
Attainable Rate is 49336 / 17002 kbps
Speedtest Download speed is showing 13.4 mbps (Could be weekend congrstion?)
However IP Profile is 23.88 / 10 Mbps
Any ideas please?
Message 22 of 45
Try a speed test at non peak times and see if it improves.
Message 23 of 45
IP profile shouldn't be that low with a sync speed of 49meg.
abathingape
Message 24 of 45
@gg30340
Tried speed test this morning.
Speedtest Download speed is showing 23 Mbps.
Looks like the IP Profile is restricting my speed?
Message 25 of 45
Yeah something isn't right, perhaps mods could take a look
Message 26 of 45
Your speed sets the IP profile not the other way round.
abathingape
Message 27 of 45
So how can this be resolved as it's way below what I was offered?
Message 28 of 45
Just to rule out your equipment can you take your router out of the loop by connecting your computer to directly to the modem and run a speed test again.
abathingape
Message 29 of 45
@gg30340 i've already did that following the above instructions 🙂
Message 30 of 45
There would appear to be a problem prior to your property so I doubt anybody on the forum will be able to help.
I have notified the moderators of the forum about your problem. Once they have read this they may be able to help. They are a BT UK based team and if they can help they will reply via this thread asking you to contact them via a link. They are very busy at present so once you have replied to them by the link, it can take 48 hours for them to re-contact you.
