Venomx
Expert
Message 41 of 45
Re: Why does my Line Speed Drop?
What sort of speed are you looking to get ?
Sage
Sage
Message 42 of 45
@abathingape wrote:
Just an update.  No reply from the mods yet but since my last restart, there have been no resyncs.
Connection is still:
Sync 50142 / 9997 kbps
Attainable Rate is 49336 / 17002 kbps
Profile is still 23mbps though 😞
Don't worry, they will get to you when your form reaches the top of the pile. Currently 3-5 days as they are only a small team
Sage
Sage
Message 43 of 45
I should imagine somewhere near the sync rate after allowing for overheads.
abathingape
Message 44 of 45
"I should imagine somewhere near the sync rate after allowing for overheads."
This 🙂
Moderator
Moderator
Message 45 of 45
@abathingape Thanks for speaking with me today, I'm glad your connection speed has improved after the engineer visit today. If you need any further help let us know Smiley Happy
