Nahoya
Message 1 of 4
Why is infinity 2 slower than expected
Hi
I've just increased my package from infinity to infinity 2 with speed expected around 60 Mbpm but the speed is much lower and it shows  as if \i'm still on the infinity 1 package with the speed not more than 38Mbpm. I wonder if you can help. It's really annoying paying for something and not getting what you are paying for.
I'm posting the statistics of each settings for reference. I tried resetting my HH5 several times but this did not solve it.
Noha
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: Why is infinity 2 slower than expected
When you change from Infinity 1 to Infinity 2, all that changes is the maximum speed cap from 40/10 to 80/20. Your line appears to be running as fast as it can.
If not, I'll try again 🙂
het_uk
Message 3 of 4
Your connection is probably operating within the parameters of FTTC Range B.  This is acceptable but may indicate wiring issues either inside or outside your home.
dfenceman
Expert
Message 4 of 4
@Nahoya wrote:
Hi
Noha
Can you post the result of the further diagnostics from the speed test please ?
Best regards,
dfenceman
