HenryPE
Message 1 of 11
Why is my Upstream only 2.7 Mbps?
I recently had Infinity installed and am only getting 2.75 mbps upstream? The 20 Mbps downstream is acceptable.
This is with the HH5 plgged directly into the master socket.
Here are the diagnostic screens.
Thanks.
1. Product name:BT Home Hub
2. Serial number:+068543+NQ52012951
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 05/09/15
4. Board version:BT Hub 5A
5. DSL uptime:6 days, 02:11:31
6. Data rate:3051 / 23228
7. Maximum data rate:3020 / 22170
8. Noise margin:5.6 / 7.5
9. Line attenuation:37.5 / 28.4
10. Signal attenuation:37.4 / 23.8
11. Data sent/received:905.9 MB / 9.6 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:XX
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:XX
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:54:64:d9:15:bd:4c
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.204.1.11 | Last updated 05/09/15
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 22.03 Mbps
0 Mbps22.48 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 22.03 Mbps
 For your connection, the acceptable range of speedsis 15.74 Mbps-22.48 Mbps .
 Additional Information:
 IP Profile for your line is - 22.48 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 2.75 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 2.75Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
10 REPLIES 10
Sage
Sage
Message 2 of 11
Re: Why is my Upstream only 2.7 Mbps?
Can you enter your phone number HERE and post the results. Remove your phone number before posting.
HenryPE
Message 3 of 11
BT BROADBAND AVAILABILITY CHECKER
Telephone Number 017332 on Exchange GLINTON is served by Cabinet 6
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
  HighLowHighLow
FTTC Range A (Clean)36.427.97.55.5--Available
FTTC Range B (Impacted)3016.47.43.7--Available
WBC ADSL 2+Up to 6--4 to 8Available
WBC ADSL 2+ Annex MUp to 6Up to 14 to 8Available
ADSL MaxUp to 5--3.5 to 7.5Available
WBC Fixed Rate2 ----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
For all ADSL and WBC Fibre to the Cabinet (FTTC or WBC SOGEA) services, the stable line rate will be determined during the first 10 days of service usage.
This line has jumpers in place.
For FTTC Ranges A and B, the term "Clean" relates to a line which is free from any wiring issues (e.g. Bridge Taps) and/or Copper line conditions, and the term "Impacted" relates to a line which may have wiring issues (e.g. Bridge Taps) and/or Copper line conditions.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 15-Sep-2014; the Formal Retirement date for IPstream is from 30-Nov-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Note: If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number check.
Thank you for your interest.
Sage
Sage
Message 4 of 11
Have you tried connecting to the test socket to see if that gives better results?
Try a quiet line test in 17070 option 2, if any noise on the line report a phone line fault, don't mention broadband.
BT won't take any action within the first 10 days (except line faults) to allow DLM to do its' work although it is quicker than that normally. Your downstream at present is lower than the range A estimate and if stays there would need looking at.
Post back after the 10 days if it hasn't improved by then.
HenryPE
Message 5 of 11
Thanks for your help.
It is plugged into the test socket.
The line is quiet.
The Infinity has been in operation for 23 days and has not changed.
Who should I contact?
Message 6 of 11
sorry is hub connected to test socket or as your previously said 'connected to master socket'?  test socket.jpg
HenryPE
Message 7 of 11
It is the same whether the HH5 is plugged into the test socket or the Openreach VDSL SSFP Mk2 socket.
Prior to fitting the SSFP I found that the I-plate and extension reduced the speed to 8 Mbps. Since I removed the I-plate and the extension wiring and fitted the SSFP the speed is about 20 D/2.7 U Mbps whchever socket it's plugged into.
HenryPE
Message 8 of 11
Can anybody help?
Thanks.
Message 9 of 11
can you post up to date stats as 20/2.7 is lower than initial stats  are you connected to test socket?  it's possible connectiion speed does not change initially but maybe the attainable speed and noise margin increases giving more scope for improvement
HenryPE
Message 10 of 11
FAQ
 Download Speed
 17.97 Mbps
0 Mbps18.45 Mbps
 Download speedachieved during the test was - 17.97 Mbps
 For your connection, the acceptable range of speedsis 12.91 Mbps-18.45 Mbps .
 IP Profile for your line is - 18.45 Mbps
 Upload Speed
 2.77 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 2.77Mbps
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
5. DSL uptime:7 days, 14:04:49
6. Data rate:3163 / 19061
7. Maximum data rate:3459 / 20621
8. Noise margin:4.8 / 7.7
9. Line attenuation:37.2 / 28.4
10. Signal attenuation:37.3 / 23.9
11. Data sent/received:1.7 GB / 18.6 GB
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:Wyreless_B5
18. 5 GHz Wireless network/SSID:Wyreless_5GHz
As of now 18:00 2/10/2015 connected to test socket.
Thanks.
