BinarySpeaking
Message 1 of 24
Why is my upload so poor (1.5mb) ?
Hi
I am getting 17mb download, but only have 1.5mb upload. . . it used to be 4mb.
Why don't BT speed tests show the upload speed?
Is there a way to get BT to look at the upload speed?
23 REPLIES 23
Message 2 of 24
Re: Why is my upload so poor (1.5mb) ?
enter your phone number and post results  remember delete number  http://dslchecker.bt.com/adsl/adslchecker.welcome
run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection and preferably with IE/edge as firefox/chrome are giving odd results
if you are on adsls conenction then max up speed is about 1/1.2mb
BinarySpeaking
Message 3 of 24
Telephone Number 01189****** on Exchange SPENCERS WOOD is served by Cabinet 3
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)22.7152.91.313.1Available----
VDSL Range B (Impacted)17.57.92.70.85.3Available----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 1.5--1 to 3.5Available--Yes
WBC ADSL 2+ Annex MUp to 1.5Up to 0.51 to 3.5Available--Yes
ADSL MaxUp to 1--0.75 to 2.5Available----
WBC Fixed Rate0.5----Available--Yes
Fixed Rate0.5----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date25-05-2018
BinarySpeaking
Message 4 of 24
Your speedtest results
BT Exchange => BT Home Hub
Download  17.3Mb/s
Message 5 of 24
the speedtest is not from diagnostic results as that will much more information including your down and up speed and profile. Can you run btspeedtester diagnostic test using the link I previously posted
you have posted in the adsl/copper connection but from your comments and dslchecker results I think you have FTTC not adsl2
can you post stats from your router
BinarySpeaking
Message 6 of 24
Hi imjolly
The only link I found on your original post was to  http://dslchecker.bt.com/adsl/adslchecker.welcome
This asked for a landline number which I entered. . . it produced a table which I duly cut and pasted above. On this form there was no other link to a diagnostic test. . .I am therefore fairly confused now.
I do not believe we have FTTC, but POTS as the road out side our house is lined with telegraph poles and our service definitely comes from telegraph pole which I assume is copper and therefore POTS.
Would be grateful if you could (re-)post the btspeedtester diagnostics link
Thank you in advance for your help here. . .
conrad
Recognised Expert
Message 7 of 24
Use this link and when test done click on the further diagnostics and post results - be aware it is tempermental and may need several goes to finally produce the diagnostic results which will show the IP profile needed      http://www.speedtest.btwholesale.com/
Message 8 of 24
FTTC - fibre to the cabinet - and then copper from the cabinet on telegraph poles in your case to your home so I think you have BT infinity which is described as a fiber conenction as against a coppre wire conenction all the way back to the exchange  if that were the case you would not have a down speed of 17mb according to dslchecker
can you post stats from your router  if unsure then which hub/router do you use?
BinarySpeaking
Message 9 of 24
1. Best Effort Test:  -provides background information.
 Download Speed
 16.87 Mbps
0 Mbps17.47 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 16.87 Mbps
 For your connection, the acceptable range of speedsis 12.23 Mbps-17.47 Mbps .
 Additional Information:
 IP Profile for your line is - 17.47 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 1.46 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 1.46Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
 Please visit the FAQ if you are unable to understand the test results.
BinarySpeaking
Message 10 of 24
I have a BT Home Hub 4 Type A
I see there is download software for HH3 and 5 but not 4?
