Message 11 of 24
Re: Why is my upload so poor (1.5mb) ?
do you also use a modem connected to phone socket and then router hh4 connected to modem?
with the 20mb up profile shown on btspeedtester results you are on infinity 2 or a recently free upgraded infinity 1
Message 12 of 24
@BinarySpeaking wrote:
1. Best Effort Test:  -provides background information.
  Download Speed
  16.87 Mbps
0 Mbps 17.47 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 16.87 Mbps
 For your connection, the acceptable range of speedsis 12.23 Mbps-17.47 Mbps .
 Additional Information:
 IP Profile for your line is - 17.47 Mbps
2. Upstream Test:  -provides background information.
  Upload Speed
  1.46 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 1.46Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
 Please visit the FAQ if you are unable to understand the test results.
You are on fibre to cabinet not adsl (copper broadband )
BinarySpeaking
Message 13 of 24
Thanks imjolly
Guess I have posted in the wrong Forum. . . sorry for this, I will repost in the correct forum.
Message 14 of 24
I will move this thread to correct board
Message 15 of 24
As you are using a hh4 with a modem then all the relevant stats are in the modem and unless unlocked are not accessible
BinarySpeaking
Message 16 of 24
From the master socket, there is a cable which goes into the DSL port on a BT OpenReach box mounted next to the master socket. From the BT OpenReach box a LAN cable goes to the HH4 Type A. . . no other ports are in use (except of course for a power cable).
BinarySpeaking
Message 17 of 24
Would upgrading the equipment improve matters?
Message 18 of 24
I doubt it. You current connection speed up and down are within your estimated speed when you look at the dslchecker results
instead of connecting to master socket have you tried connecting to the test socket (which is behind the master faceplate) with a filter and see if that helps your connection speed
BinarySpeaking
Message 19 of 24
Thanks imjolly, I am pretty disappointed as it was once consistently over 2mb with 20mb download which was acceptable. Since a fault appeared over next doors pole a few months ago and we lost service completely. An engineer came out and managed to get the service restored, but it was different... definitely a poorer service... maybe once a day it hangs drops out... and we have to wait for it to reestablish.
For £75 a month... it isn’t what I would consider an acceptable service. Just pay your money and be quiet
Message 20 of 24
TYour connection should not drop on daily basis.  The drops have more than likely affected your connection speed but without the router stats you cannot really tell
i would certainly try connecting to test socket with a filter and see if it makes line more stable and even improve your connection speed
is there any noise on quiet line test. Dial 17070 option 2 should be quiet apart from the announcement and best with corded phone
i would also phone options team 0800800030 and see about downgrading to infinity 1 which will not affect your speed up or down but should reduce your monthly cost
