imaner76
Message 1 of 15
Why is "SUPERFAST FIBRE 2 UNLIMITED" 67MB always capped at various lower speeds for me?
I have had many differing speeds for set periods of time. 32MB that dropped to 24MB, I said I'd like to move and got 38MB. but that swaps to 36MB for days at a time. All while still paying for the 67MB.
Now it's capped at 3.5MB.
Why are the caps applied and what qaulifies me for a higher cap on speed? Is there an option to reduce my plan to pay for what I'm actually getting?
14 REPLIES 14
Message 2 of 15
Re: Why is "SUPERFAST FIBRE 2 UNLIMITED" 67MB always capped at various lower speeds for me
enter your phone number and post results  remember dlete number but leave exchange and cab  https://www.btwholesale.com/includes/adsl/main.html
the main of lower speed is your distnace from your street cabinet and then the quality of your line
post stats from your router
check your line for noise  dial 17070 option 2  should be silent and best with corded phone
are you using test socket with a filter
Message 3 of 15
The 67Mb is an average over every customer, not your individual speed. Your speed is not capped (except to 80Mb) but will only be as fast as your individual line will support. If there is a fault on your line it will reduce your speed.
imaner76
Message 4 of 15
VDSL.pngThe results
imaner76
Message 5 of 15
Yes I know that's an average, but the sales team that moved my wife to the higher option will have access to what speeds the line may potentially reach. I've looked at the options and a deal half the price with a 50MB average would have covered the line speed if that is only able to achieve 36MB?
imaner76
Message 6 of 15
1. Best Effort Test:  -provides background information.
 Download Speed
 1.77 Mbps
0 Mbps1.82 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.77 Mbps
 For your connection, the acceptable range of speedsis 1.27 Mbps-1.82 Mbps .
 Additional Information:
 IP Profile for your line is - 1.82 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 3.62 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 3.62Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Message 7 of 15
Can you post your router stats please?
There's really not a lot of point in paying for Superfast 2 as your highest projected speed is only a fraction higher than Superfast 1 in any casee.
Message 8 of 15
From your profile your speed is very low check line for noise assuming you get a dial tone
Can you also connect to test socket with a filter and post the router stats
imaner76
Message 9 of 15
I agree, hence my annoyance with the BT sales staff. I'm a field marketing manager, I know a little about targets. I'd be interested in the check tools they have on hand before selling a product.
Forgive my ignorance but do you have a pathway to get the router stats?
Message 10 of 15
If the hub 6, then Advanced settings > Technical log > Information
Was the speed test done with a wired or wireless connection?
