imcal007
Message 1 of 10
Why the Slowdown
Last few weeks i have noticed that my download speed as slowed down and upload speed as also slowed, my ping has gotten higher and game lag on the ps4/3 has increased sometimes it is unplayable making me question the reason i jumped from Virgin..
Just done a speed test
45,86mbps download
12.67mbps upload
ping 33ms
any ideas
9 REPLIES 9
dfenceman
Expert
Message 2 of 10
Re: Why the Slowdown
How laong have you had Infinity 2 and what was your speed at installation ?
Best regards,
dfenceman
Message 3 of 10
If you have the hh5 go to hub manager then troubleshooting then helpdesk and post 1-12
enter your phone numberand post results  https://www.btwholesale.com/includes/adsl/main.html
imcal007
Message 4 of 10
When i first had Bt
In a post on this forum i stated that the speed was as follows
ping 12 ms - download 69.09 mbps upload 16.37 mbps
now its
45,86mbps download
12.67mbps upload
ping 33ms
Also since the problem Bt had a few weeks ago where the websites wouldnt appear certain websites i just cant connect to, ie resolving host then nothing.
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date  High Low High Low
FTTC Range A (Clean)79.4602019.6--Available
FTTC Range B (Impacted)70.543.82013.8--Available
WBC ADSL 2+Up to 13.5--10 to 17.5Available
WBC ADSL 2+ Annex MUp to 13.5Up to 110 to 17.5Available
ADSL MaxUp to 6.5--5.5 to 8Available
WBC Fixed Rate2----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
dfenceman
Expert
Message 5 of 10
Hi imcal007,
It might be worth you taking a look at this https://community.bt.com/t5/BT-Infinity-Speed-Connection/Crosstalk-amp-Vectoring/td-p/1323205
Best regards,
dfenceman
Distinguished Guru
Message 6 of 10
Do you have a Homehub 5 ?
If not, I'll try again 🙂
imcal007
Message 7 of 10
Thanks dfenceman for the link i`ll look into that about crosstalk
And yes Ray i do have homehub 5, Thanks
Distinguished Guru
Message 8 of 10
Can you go into the web console for the Homehub and post your line stats from Troubleshooting/Helpdesk please?
Lines 1-13 will be enough
curiousfellow
Message 9 of 10
BT are definitely up to something. I was getting 53-56 mb download speed for the best part of a year. A couple of months ago I suddenly found my speed down to 49.5 mb.
Waste of time complaining because bt like all isps just comes out with rubbish such as are you testing wirelessly, do you have an extension circuit blah, blah, blah.
Guru
Message 10 of 10
Lowering speeds don't necessarily mean BT are 'up to something'. BT Openreach may be connecting new FTTC users (possibly to BT Infinity or possibly for other isps) which can slow existing users because of crosstalk ( see dfenceman's post above). Or you or someone else may have installed some new equipment that causes interference.
