Community Manager
Community Manager
Message 21 of 22
Re: Wifi stable for months, now dropping out twice a day
Hi @Burmey
Good speaking with you there.
The line is not banded and the speed is well within range for your connection, however I know you've had problems with line stability for a considerable amount of time so we've agreed to keep this case open for a while longer, and if there's still a fault we'll take it from there.
Community ModeratorStephanie
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Community Manager
Community Manager
Message 22 of 22
Hi @Burmey
Thanks for speaking with me this evening. Good to hear that you are happy with your connection, please post back if there's anything else we can help with!
Kudos”
