Message 1 of 8
Will BT be able to get me above my guaranteed speed?
After a total nightmare getting activated for fibre and over three weeks without broadband I have finally now got fibre. I was previously on an EO-Line with the highest speed of around 1.8mpbs. My line was to be diverted into a fibre cabinet and Openreach had said the work was completed when it wasn't and BT took my order and the cables weren't even in the cabinet yet! So my old provider cut me off and I was left with nothing. Anyway, this all sorted I am now on a fibre connection getting a speed of 23-24mpbs Big improvement, but My package stated a minimum speed of 27mpbs with an estimated 30-43mbps. I know its not a huge difference but it is below my minimum guaranteed speed and I've never come close to the estimated speeds. Now to the question. for some bizarre reason, I have been diverted into a cabinet around 1km from my home (previously 3.5km to exchange)  despite there being a new fibre cabinet installed last year in my street just 75-80 meters from my home! Taking into account the distance to my cabinet will they be able to improve the speed? or am I simply limited by the line length. I knew I wouldn't get blistering speeds when I learned the location of the cabinet but I would have thought it would have all been worked out in my minimum. I don't know why I am not in my closest cabinet.
Any info or experience would be appreciated.
Thanks,
David
7 REPLIES 7
Recognised Expert
Message 2 of 8
Re: Will BT be able to get me above my guaranteed speed?
What does the speed checker  show for your phone number
https://www.dslchecker.bt.com/
Perhaps you can post your router stats....is your router connected at the master socket ?, if you haven't done so already, you could try connecting your router in the master socket test port, that way, eliminating and possible issues with extension wiring/sockets that you are responsible for.
You obviously realise that the distance you are from the cabinet is the major factor determining the speed you will sync at, if you don't achieve the minimum speed guarantee then AFAIK,your ISP should try and get you up to that speed and if they cannot, allow you to leave penalty free if you wish, but presumably you have to ensure you don't have issues within your home that they ( and Openreach) are not responsible for, first.
Message 3 of 8
Thanks for getting back to me. The site you linked gave me this information...
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low
VDSL Range A (Clean)40.527.47.75.322.7Available----
VDSL Range B (Impacted)39.524.17.5519.9Available----
This is a quick overview of your BT Smart Hub's status.
 Connection status:
BT Broadband /
BT Infinity /
BT Ultrafast:
BT Infinity
 Firmware version:
SG4B1A006100
 Serial number:
+088293+NQ74465045
 Downstream sync speed:
25.15 Mbps
 Upstream sync speed:
5.37 Mbps
 Network uptime:
0 Days, 5 Hours 11 Minutes
 System uptime:
0 Days, 5 Hours 13 Minutes
 BT Wi-fi status:
Active
I am connected to the master socket.
Sage
Message 4 of 8
Those aren't the required connection stats.
HH6 Advanced settings/technical log will get them for you to post.
Message 5 of 8
can you also try connecting to the test socket with a filter as @iniltous asked as that should be your best conenction even if you currently have a filtered master socket
Message 6 of 8
Sorry for the delay here is the info requested.....
 I do not have a pre-filtred socket and im using a micro filter
Product name:
BT Hub 6XA
Serial number:
+088293+NQ74465045
Firmware version:
SG4B1A006100
Firmware updated:
14-Nov-2018
Board version:
1.0
Gui version:
1.85.0
DSL uptime:
3 Days, 15 Hours 34 Minutes 29 Seconds
Data rate:
5.37 Mbps / 25.15 Mbps
Maximum data rate:
5494 / 30185
Noise margin:
6.2 dB / 6.2 dB
Line attenuation:
0 dB / 26.5 dB
Signal attenuation:
0 dB / 26.5 dB
VLAN id:
101
Modulation:
G.993.2 ANNEX B
Upstream error control:
Downstream error control:
Data sent / received:
230.57 Mb Uploaded / 4.09 Gb Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BT-TWX2
2.4 GHz wireless channel:
Channel 6
5 GHz wireless network name:
BT-TWX2
5 GHz wireless channel:
Channel 36
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:39:EE:79:B2:2F
Software variant:
Boot loader:
9.2.0
Message 7 of 8
Message 8 of 8
I am in the test port now. No major Differences.
Just out of interest what does plugging into the test port do?
Thanks...
Product name:
BT Hub 6XA
Serial number:
+088293+NQ74465045
Firmware version:
SG4B1A006100
Firmware updated:
14-Nov-2018
Board version:
1.0
Gui version:
1.85.0
DSL uptime:
0 Days, 0 Hours 2 Minutes 6 Seconds
Data rate:
5.40 Mbps / 26.08 Mbps
Maximum data rate:
5509 / 31024
Noise margin:
6.3 dB / 6.2 dB
Line attenuation:
0 dB / 26.5 dB
Signal attenuation:
0 dB / 26.5 dB
VLAN id:
101
Modulation:
G.993.2 ANNEX B
13.59 Mb Uploaded / 57.08 Mb Downloaded
Broadband username:
BT Wi-fi:
Active
BT-TWX2
Channel 6
BT-TWX2
Channel 36
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:39:EE:79:B2:2F
Software variant:
Boot loader:
9.2.0
