CJPT
Newbie
Message 1 of 3
Will an upgrade disable my connection?
Hi there, I'm looking to upgrade from an older Superfast Fibre 2 package to the Ultrafast Fibre Plus. If I do so, will I lose my internet connection in the week between booking the upgrade and the engineer appointment?
2 REPLIES 2
Message 2 of 3
Re: Will an upgrade disable my connection?
no
Moderator
Moderator
Message 3 of 3
@imjolly wrote:
no
Welcome to the Community @CJPT.
@imjolly is spot on and the switch would should be done without loss of service 🙂
Community ModeratorMatt
Show your appreciation!
Kudos”Kudos”
