Stuartd
Message 1 of 46
Work out line stats?
Hi all,
Could you help me work out my stats?
Over the the last few days my download noise margin has gone from 6 to 4.9, does this mean that there is more noise on the line and if it continues to lower I could see a disconnect?
i have also noticed that the Smart Hub restarts itself every 2 weeks, could that affect the chances of any recoup of speed?
45 REPLIES 45
Message 2 of 46
Re: Work out line stats?
@Stuartd wrote:
Hi all,
Yes and possibly.
Not really, DLM won't notice such infrequent disconnections.
Stuartd
Message 3 of 46
Thank you for the reply 🙂
Crosstalk or something like that affecting the noise? Has been the same up till now?
Message 4 of 46
Could be anything, could be crosstalk could be a line fault developing. Is your phone quiet on the quiet line test 17070?
Stuartd
Message 5 of 46
I havent done the line test yet I am picking up a landline phone tomorrow as normally we do not use the line at all.
Where the line comes in, instead of being  from a pole it comes up from just outside the house and into the wall on a metal sheath, however at the top it the cover is damaged exposing the cable that comes into the house. Could this be causing a problem and how would I go about fixing this. We have recently moved it and this damage was already done.
Message 6 of 46
Possible, you could try reporting it as a fault.
Message 7 of 46
you will need Openreach to resolve that and the visit would be chargeable
Message 8 of 46
Hmm, not sure about that if it is Openreach property that is the problem.
Stuartd
Message 9 of 46
Hi all,
I have fixed the cover by ordering a new one, they only cost around £2.50 so it wasn't exactly a costly fix, however it has not cured the issue. Last night my router did the 14 day reset and despite being connected the whole 14 days without dropping once my speed has lowered.
What seems to happen is the noise margin on the download drops to 4.x and then doesn't recover, I am expecting the same to happen again in this two week period and for the line to drop lower again. It started at at 76Mbps connection and now we are down to 65Mbps. If this router didn't reboot then I would imagine that my line would still be connected at 76Mbps for the most part as my line wasn't droppping.
Message 10 of 46
Post the results for your line from http://www.dslchecker.bt.com
