Message 1 of 6
Would replacing BTHH3 router with updated model help with wifi range issues.
I've been having issues for few months and even connected ethernet cables for 2 connections upstairs which is not ideal.  Wifi drops out intermittently on mobile devices.  Have done wholesale speed test which shows results > what I am actually getting.
5 REPLIES 5
Sage
Message 2 of 6
Re: Would replacing BTHH3 router with updated model help with wifi range issues.
If you are going to purchase a replacement you'd be better off getting a third party router.
Message 3 of 6
@MsBkl This one works just fine, and has good wireless range .
TP-Link TD-W9970 for about £40 or less.
A good set of features http://uk.tp-link.com/products/details/cat-15_TD-W9970.html#specifications
Message 4 of 6
I have a new hub and find the range and coverage  better overall than the more expensive tplink vr2600 with 4 external aerials    however the tplink certainly has better features than the hub
Message 5 of 6
Thank you for response. What would be the benefit of going to third party hub?
Message 6 of 6
Full control over how you configure the router, without any unwanted interference from BT.
Lots of extra feature which are not present on the home hubs, like a guest network and bandwidth controls. Also the ability to turn off wireless to a schedule.
Not all third party routers have this, but the one I mentioned does. Read the specification, and if there is any aspect that you need explaining, I have quite a lot of extra information on my website.
