galabonnyboy
Message 1 of 6
Wrong IP Profile
I noticed my broadband speed has been slow for the first time in years, only 6-7mb and its always been over 70 since 2016 constantly.
Went and done an BT Speed test and noticed my IP Profile is set at 20MB??
Can I get this fixed please I'm on the superfast unlimited 2 package and should be 70+
Here is my current sync (not changed), no error seconds on the downstream and just the usual ammount on the upstream (30 or so a day)
5 REPLIES 5
PaddyB
Moderator
Moderator
Message 2 of 6
Re: Wrong IP Profile
Hi @galabonnyboy,
welcome back to the community. I'm sorry you've had a drop in speed.
Have you notice any issues with the stability of your connection?
To help rule out any issue with your phone service please run a quiet line test by dialling 17070 from your BT Landline. If using a corded phone then the test should be quiet, if you are using a cordless phone then you may hear a low hum.
PaddyB
pompey1898
Recognised Expert
Message 3 of 6
And @PaddyB ,
If you look, you will see that it is giving the same figures fo down and up.  This is happening quite regularly, that is if the Further Diagnostice work at all.
PaddyB
Moderator
Moderator
Message 4 of 6
Hi @pompey1898,
I missed that, I didn't notice the the upload and download speeds are the same Smiley Embarassed
@galabonnyboy can you try running the speed test through your My BT?
PaddyB
galabonnyboy
Message 5 of 6
Line has been normal no disconnects and error seocnds are normal too. Download & Upload speed are still terrible
Cant get the my BT speed test to work as I'm not using the BT hub
Tags (1)
galabonnyboy
Message 6 of 6
Nevermind guys, turned out to be a faulty switch in my house. The speed at the router is normal so thanks for your help anyway
