Message 1 of 2
Xbox App on PC can't find Xbox One
Hi all,
I can't seem to remote play on my PC from my Xbox One. I've tried everything.
I open the app on my PC and it doesn't find the console, so I enter my IP and it still isn't found?
The app on my phone finds the Xbox, so any ideas why my PC won't?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Xbox App on PC can't find Xbox One
Hi @jaydog69,
If you take a look at - My Xbox One isn't visible in the Xbox app on Windows 10 you'll find some useful information.
If you're using a BT Home hub you'll need to split the SSID's for the 2.4 GHz and 5 Ghz.
How do I split my BT Hub's SSID (wireless network name)?
Give that ago and let me know how you get on?
PaddyB
