BasingBoy
Newbie
Message 1 of 2
another Infinity Upload Speed suddenly dropped
Hi. Was this ever resolved. Mid April I went from 5up to now 1 and after three engineer visits there is no conclusion
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: another Infinity Upload Speed suddenly dropped
Hi @BasingBoy and welcome.
Sorry for the delay in getting back to you. I'm sure we'll be able to help. Can you please run the speed test including the further diagnostics on a wired connection and post the results.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
