satch2107
Message 1 of 6
broadband speed too slow for NetFlix
Few times lately I have tried to watch Netflix opnly to be told they are sorry at this time cannot show anything., When I go to help section of netflix and do a system check I find I am only getting a speed of 25mb etc's whjere my speed should be some where above 55 Mb's I pay £43+ for broadband of the Infinity type so it should be better than this.
satch
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: broadband speed too slow for NetFlix
Hi @satch2107,
What speeds do you get on your other devices? Is it the same for them all? Also, what device are you watching Netflix on?
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
Message 3 of 6
Post stats from hub
hh6 advanced settings then technical log information
hh5 then troubleshooting then helpdesk
enter phone number and post results. Delete number   https://www.btwholesale.com/includes/adsl/main.html
Distinguished Guru
Distinguished Guru
Message 4 of 6
satch2107
Message 5 of 6
Well thank you for that info, so why do I get the message saying " sorry we can't show you this title at the moment, please try another one"
satch
Message 6 of 6
