ashley01uk
Message 1 of 16
bt Internet in my area
Hi guys just a quick question I'm am currently with virgin media and the speeds in my area are very poor I'm getting 3mb at night if that and I'm paying for 60mb my question  is can anyone tell me if b.t interest is good in my area I live in Penn warstones  wv4 area ??
15 REPLIES 15
dombullion
Message 2 of 16
Re: bt Internet in my area
Hi ashley01uk,
This looks like the exchange you might be on: http://www.samknows.com/broadband/exchange/CMPEN
and it shows FTTC available in some areas.
This address which might be close to you shows the speed of FTTC available:
Address 170 WARSTONES ROAD, PENN, WOLVERHAMPTON, WV4 4LF on Exchange PENN is served by Cabinet 11
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date  High Low High Low
FTTC Range A (Clean)8079.92020--Available
FTTC Range B (Impacted)8077.62019--Available
WBC ADSL 2+Up to 5--3 to 7.5Available
WBC ADSL 2+ Annex MUp to 5Up to 13 to 7.5Available
ADSL MaxUp to 4--2.5 to 7Available
WBC Fixed Rate2----Available
Other Offerings
Fibre Multicast------Available
Hope this helps,
Dominic
Message 3 of 16
As per the checker:
If you are doing and address check is less accurate than the telephone number checker because the result is not based on an individual telephone line at the premises. BT's ability to provide Broadband to your address is dependent on the presence of an existing BT line and other factors, including the availability of broadband at your serving exchange, and the length of the line connecting you to the exchange.
I found that the address checker gives a higher estimate than the phone line checker.
ashley01uk
Message 4 of 16
hi yes thanks for the help guys i currenty dont have a bt line installed so i cant do that do they charge to get a line installed ?
dombullion
Message 5 of 16
Hi,
Take a look at the following link:http://www.productsandservices.bt.com/products/broadband/packages/?infinity=yes
It indicates that on BT Infinity Option 1 there is a £30 activation charge but no connection charge as this is included and for Option 2 both are free.
This will save you a lot of money as the standard connection charge for a brand new BT line is £130
Hope this helps,
Dominic.
Message 6 of 16
Not if you are going for the Totally Unlimited Infinity packages. See link
http://www.productsandservices.bt.com/products/broadband/packages?Infinity=yes
ashley01uk
Message 7 of 16
oh ok thanks guys just hoping that if i do change from virgin media im not going to be having the same problems im getting now 🙂
Message 8 of 16
Unfortunately you will never know until you are connected up but going by the estimates, even allowing for a bit of over estimation you should get good speeds.
ashley01uk
Message 9 of 16
yeh i know hhaha thanks for the help i think il be giving them a call tomorow and see when i can switch had enough of this virgin media utilisation problem in my area been goin on for over a year now 😞
Sage
Sage
Message 10 of 16
@gg30340 wrote:
As per the checker:
Sorry gg but it has nothing to do with the length of the line to the exchange as you should well know when referring to FTTC services. The OP can only get an estimate from the postcode checker (or better the address checker) as he is with Vermin ATM.
