lnewey6
Message 1 of 10
bt fibre plus
hi i have bt fibre plus average 67mb  but i only get 37mb is that right because i used to get 60mb a few years ago
9 REPLIES 9
Distinguished Guru
Distinguished Guru
Message 2 of 10
Re: bt fibre plus
Any noise on your line? 17070 option 2.
Message 3 of 10
Re: bt fibre plus
enter your phone number and post results  remember delete number but leave exchange and cab  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Moderator
Moderator
Message 4 of 10
Re: bt fibre plus
Hi @lnewey6 ,
Welcome to the community and thank you for posting. Please can you try the steps as suggested by @imjolly and @pippincp. This will help to give an indication of how your connection is performing and what can be done to improve your speeds.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
lnewey6
Message 5 of 10
Re: bt fibre plus
Moderator
Moderator
Message 6 of 10
Re: bt fibre plus
Morning @lnewey6  and thanks for posting those details.
Can you also try running a speed test on a wired connection and post the results?
Cheers
David
Community ModeratorDaveM
Kudos”Kudos”
lnewey6
Message 7 of 10
Re: bt fibre plus
Download Speed (Mbps): 36.40 Upload Speed (Mbps) : 8.31 Ping Latency (ms): 35
Message 8 of 10
Re: bt fibre plus
was there any noise on quiet line test?
can you post hub stats  if hh6 then advanced settings then technical log information   if hh5 then troubleshooting then helpdesk
lnewey6
Message 9 of 10
Re: bt fibre plus
his is a list of your BT Smart Hub settings and current statistics.
Product code:Smart Hub 2 Serial number:+091298+1834008844
Firmware version:v0.12.02.11078-BT
Firmware updated:Tue Jan 22 00:11:08 2019
Board version:R01 GUI version:1.53a 29_08_2018
DSL uptime:18 days,00 Hours02 Mins03 Secs
Data rate:9.999 Mbps / 43.998 Mbps
Maximum data rate:11.607 Mbps / 53.134 Mbps
Noise margin:7.7 / 9.1 Line attenuation:12.3 / 20.9
Signal attenuation:12.3 / 25.5 VLAN id:101
Upstream error control:Off
Downstream error control:Off
BT Wi-fi:Activated 2.4 GHz wireless network name:BT-3FA2X5 2.4 GHz wireless channel:Smart (Channel6) 5 GHz wireless network name:BT-3FA2X5 5 GHz wireless channel:Smart (Channel36) Wireless security:WPA2 (Recommended) Wireless mode:Mode 1 Firewall:On MAC address:4C:1B:86:8D:7F:C8 Software variant:- Boot loader: 0.1.7-BT (Thu Nov 30 09:45:22 2017
Moderator
Moderator
Message 10 of 10
Re: bt fibre plus
Hi @lnewey6 ,
Thanks for posting the stats, appreciate it. What stands out here is the up time is over 18 days. Your connection speed is within expectations (referencing your initial post). I can understand you might have hoped for a faster speed but there doesn't appear to be any problems looking at those stats.
Cheers
David
Kudos”Kudos”
