thomasmulhall
Message 1 of 2
bt infinity 2 telephone fault
hi i think i have a fault on the line because today the internet slowed down to 8 mbps from 76 mbps on 2.4 ghz and 5 ghz i think. please help me. i try reporting the issue online but since i did it in february it now says there is no fault on the line please help.
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: bt infinity 2 telephone fault
If you want to get a more reliable answer, you really need a wired connection.
