l33th4ll
Newbie
Message 1 of 24
bt infinity nightmare to get
Hello
im starting to get wound up due to no one being able to answer my question on bt live chat
when i use the online check it says i can only get unlimited broadband
if i use my same telephone number and any other house number it says i can get infinity
why am i the only house on the street that cannot get infinity
is this a problem with the lookup bt uses or am i being screwed over for some reason
dsl checker for my flat
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availibility Date
WBC SOGEA Availibility Date
  HighLowHighLow
ADSL Products
Availability Date
Other Offerings
Availability Date
VDSL Range A (Clean)159.91.20.8--Available--
VDSL Range B (Impacted)12.24.31.20.6--Available--
WBC ADSL 2+Up to 7--5 to 11Available--
WBC ADSL 2+ Annex MUp to 7Up to 15 to 11Available--
ADSL MaxUp to 5--4 to 7.5Available--
WBC Fixed Rate2----Available--
VDSL Multicast------Available--
ADSL Multicast------Available--
house next door
Featured Products
  HighLowHighLow
ADSL Products
Availability Date
Other Offerings
Availability Date
VDSL Range A (Clean)75.458.62018.9--Available--
VDSL Range B (Impacted)59.730208.9--Available--
WBC ADSL 2+Up to 7.5--5.5 to 12Available--
WBC ADSL 2+ Annex MUp to 7.5Up to 15.5 to 12Available--
ADSL MaxUp to 5.5--4 to 8Available--
both use the same cabinet (19)
23 REPLIES 23
Message 2 of 24
Re: bt infinity nightmare to get
are the dskchecker resukts from using your phone number as that is more accurate than address and post code
l33th4ll
Newbie
Message 3 of 24
using my telephone number on both house number
been onto bt telephone sounds like not enough cabinet space adn will have to pay for more expensive normal broadband that what infinity costs
Message 4 of 24
If you cabinet was waiting for increased capacity then you normally see a note to that affect with the checker results
Message 5 of 24
When you use the checker use only your phone number. Do not put your house number in as well.
If you are checking a neighbours house use their phone number and not their house number.
You then need to check that you are both on the same cabinet by checking the cabinet number that is shown at the top of the checker results. It may be that you are on different cabinets even although you are in the same street.
l33th4ll
Newbie
Message 6 of 24
on same cabinet checked that so sounds like i gotta pay extra and wait for upgraded cabinet which could take years 😞 and still play a **bleep** infinity activation fee
Message 7 of 24
As I said were there any notes about capacity problems with dslchecker results
Message 8 of 24
It has nothing to do with capacity otherwise you would not be able to get Unlimited Faster broadband which is Infinity. It is just not sold as Infinity because it is below 15Mbps. See link
http://bt.custhelp.com/app/answers/detail/a_id/47740/~/what-is-unlimited-faster-broadband%3F
There must be a reason why your estimate is showing as lower than your neighbour. How far are they and you from the cabinet?
l33th4ll
Newbie
Message 9 of 24
dsl checker shows no result for telephone line
There is no data available for this number. This could be either because it is not a BT line or it is a new BT number that has just been provided. Most new numbers will appear on the checker 24 hours after BT has installed the line.
l33th4ll
Newbie
Message 10 of 24
did say that to customer services and saying my postcode / number is only 10-15mbps avaliable
