sokedajo
Message 1 of 5
bt infinity
hi there,i upgraded to infinity,we had a home hub 4 installed on friday,and our vision box,tried to get bt sport,cant get it,phoned them up,and apparantly we are not on infinity,when i clearly upgraded to it when i phoned,he said they need to activate it for us their end? is that correct? many thanks
4 REPLIES 4
Distinguished Guru
Message 2 of 5
Re: bt infinity
If you are on Infinity, you would have an Openreach modem as well as a Homehub 4.
If not, I'll try again 🙂
sokedajo
Message 3 of 5
Re: bt infinity
yes we have an openreach modem too,dont really understand why he said we havent been activated for infinity,
MaryEF
Message 4 of 5
Re: bt infinity
It needs to be activated at the exchange as well as physically installed. Your confirmation emails should have given dates for both. Otherwise you will need to call BT and ask when it will be activated.
Distinguished Guru
Distinguished Guru
Message 5 of 5
Re: bt infinity
Does it? It worked out of the box for me (after some prior work at the cabinet), and this suggests that's the norm.
