Message 11 of 28
Re: constant connection issues and speed problems- Infinity
Wow I echo @pippincp comments about noise margin.  Have you tried using the test socket with a filter to see if that makes any difference
even your max attainable is only 26mb
bindi68
Message 12 of 28
I shall have a look and see if i can find a filter and give that a try
bindi68
Message 13 of 28
tried the filter in the test socket
Not any better speed wise
Firmware updated:
21-Feb-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 12 Minutes 37 Seconds
Data rate:
20.00 Mbps / 3.10 Mbps
Maximum data rate:
20417 / 26475
Noise margin:
6.3 dB / 31.5 dB
Line attenuation:
15.6 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
22 MB Uploaded / 5 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-9F3G
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-9F3G-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
Message 14 of 28
Stats from test socket not any better so I have asked mods to help - they are BT employees - and make sure engineer turns up on Thursday. Mods will post here with link to a form you need to complete
bindi68
Message 15 of 28
thank you for your help Smiley Happy
Hopefully get it finally sorted
Sage
Sage
Message 16 of 28
One mod will pick up your case after filling the form in and stay with you until resolved.
Moderator
Moderator
Message 17 of 28
Hi @bindi68
Welcome to the community and thanks for your posts!
Sorry for the connection and speed problems you're having.  From reviewing the stats you've posted, something definitely doesn't look right.  I appreciate the amount of your own time spent trying to sort this out over the last 5 months.
You can send us over your details and we'll manage everything for you from here.  We'll help get this sorted out as soon as possible.  Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
bindi68
Message 18 of 28
Have contacted the mods and have had no response yet , your fault tracker says the Broadband fault was fixed this morning at 6am ! and has been closed , today the broadband speed is WORSE barely pulling 2mbps . How do I escalate the lack of service higher as I’m now the stage where I’m questioning why I’m paying £43 a month and looking to exit my contract without clause to seek a telecoms company that can follow through and resolve faults as they occur .
Moderator
Moderator
Message 19 of 28
Hi @bindi68 Thanks for taking my call earlier and just to update the community an engineer has been booked for Thursday between 8am and 1pm to fix your fault. Please update the thread and let us know how the engineer visit went and I will be back i touch with you.
Cheers
John
bindi68
Message 20 of 28
Your welcome and thanks ,
I just don’t understand how your online fault tracker service etc says the line tests are clear and there is nothing wrong with the line and yet you tell me that there is a bad connection in the area ?!
If your online diagnostics cannot detect anything then why have it ?
Looking forward to Thursday 😃
