If it was readable I would but it isn't.
if you read some of my posts you will see i have a very similar problem and its baffling bt at the moment,mine has the similar drops in snr.
I can't understand if your connection is dropping as often as you say how you are still on fast with such a good speed and not with a very high noise margin, on interleaved and banded profile
your noise margin is dropping so low at 1db and with the noise you can hear it results in drop in connection and then you start all over again if you have had 7 openreach visits and still problems exists thehn lets get mods involved and see if they can help mods will post here but I know they are really busy so may not be till monday
hello
I know what you mean the speed is good but the speed will drop for a few seconds hard to show that in a screen shot. Strange how you look at the picture and you can see for yourselves that the dB jumps from 1-5 db in a few mins and disconnects at random times maybe once a day or 6 times a day? let’s hope the mods can help me as I have had my 7th BT engineer out on Friday 13th July and the problem been going on for the last 8 months now? Thanks for your input guys.
Hi @NIck87 Sorry you have not been able to get the fault with your broadband fixed after so many engineer visits.
We will be happy to look at your connection to see what we can do to help you if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
hello
i have reply to john c and will keep you updated here!!
thank you for the help
Hello
I have just notice in my DSL status pictures that bitswap is turn on in one picture and turn off in another picture for the SNR margin downstream only sorry got a few question?
hello
Just wondering if I got a update on my case as the engineer didn't turn up today for the appointment on the 20th July 2017 at 1pm to 6pm as I did take time off work ?
You need to see if mods can help as you contacted them already @JohnC2
