NIck87
Message 31 of 32
Re: disconnect /SNR (dB)
I don't think this is enabled because it should be 6 dB and shouldn't drop that low because of how far away I am from the  FTTC which is a 1.75 miles away ( Copper line) and looking a my previses posts you will see it drops from 6-0 dB and disconnects.
But how do I know if this is G.INP enabled thanks?
imjolly
Message 32 of 32
if on FTTC post hub stats  if hh5 then troubleshooting then helpdesk   if hh6 then advanced settings then technical log information
if you are on FTTC then it is possible for DLM to activate G.INP which drops noise margin to 3db while giving a boost in connection speed
