paul_fettes
Message 1 of 13
does anyone know what this means
(353239.010000) PPPoE is down after 24 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
HH5 light goes orange and then goes back to blue, has happened quite a lot today
12 REPLIES 12
Message 2 of 13
Re: does anyone know what this means
Your internet connection dropped after 24 minutes connection time
paul_fettes
Message 3 of 13
thanks, I get that it dropped after 24minutes, I should have asked a different question asking if anyone knows why this happens?
Message 4 of 13
This could be due to line noise or internal interference or even the DLM resetting your connection.
If if line noise try quiet line test. Dial 17070 option 2. Should be quiet and best with corded phone
paul_fettes
Message 5 of 13
quiet line test is ok, no noise on line with corded phone. home hub is new as last HH5 was dropping connection every day. thought it was fixed but not sure now
Message 6 of 13
Are you using the test socket or do you have a SSFP?
can you post router stats by going to hub manager and then troubleshooting then helpdesk and post 1-12
paul_fettes
Message 7 of 13
SSFP removed, using test socket.
1. Product name:BT Home Hub
2. Serial number:+076272+NQ52501839
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated Unknown
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:02:00
6. Data rate:6828 / 56040
7. Maximum data rate:7328 / 58144
8. Noise margin:6.1 / 6.8
9. Line attenuation:26.2 / 20.2
10. Signal attenuation:25.9 / 19.2
11. Data sent/received:250.8 MB / 10.2 GB
12. Broadband username:bthomehub@btbroadband.com
paul_fettes
Message 8 of 13
Exchange BENTON is served by Cabinet 12
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High Low High Low
FTTC Range A (Clean) 78.9 59.7 20 18.6 -- Available
FTTC Range B (Impacted) 70.4 46.2 20 13.7 -- Available
WBC ADSL 2+ Up to 17 -- 10 to 19.5 Available
WBC ADSL 2+ Annex M Up to 17 Up to 1.5 10 to 19.5 Available
ADSL Max Up to 7.5 -- 6.5 to 8 Available
WBC Fixed Rate 2 -- -- Available
Other Offerings
Fibre Multicast -- -- -- Available
Copper Multicast -- -- -- Available
Message 9 of 13
You 56mb connection speed is just below the bottom end of your dslchecker estimate. Your noise margin is slightly high at 6.8db  and that should refuse to 6db and give a bit more connection speedspeed
paul_fettes
Message 10 of 13
looking at the event log and it seems to be dropping every few minutes since about 10pm, what do you think is causing it? is it jusst the DLM trying to reset the SNR?
