Techwizz
Message 11 of 14
Re: event log error (DSL Link Down)
@Dannyw24, just to check, you've purchased a corded not a cordless phone, correct?
Dannyw24
Message 12 of 14
So after performing the noise check, I rang BT and spoke to a friendly chap, who performed a check and informed me that the connection had indeed dropped out a total of 30 times in 2 days.
He explained how a team were already looking into the problem at the exchange and how it would be fixed with 48hours. This was confirmed by an email which got sent out to me afterwards, hopefully this is the end of the road problem wise.
Message 13 of 14
I very much suspect the 'friendly chap' was giving you a load of BS. and you will need an engineer visit to rectify the problem. Time will tell.
Moderator
Moderator
Message 14 of 14
Hi @Dannyw24  How did the engineer work go and has the problem been fixed?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
