Message 1 of 3
fibre 500 new installation, slow upload speeds
Fibre 500 installed yesterday, enginerr was brilliant in accomodating where to install.
But, whilst the download speeds are fine, im stuck at 10mbs uploads.
Changed the cable, reset the hub etc, but it staedfastly will not go above 10 uploads?
2 REPLIES 2
Message 2 of 3
Re: fibre 500 new installation, slow upload speeds
there are similar posts on the forum and it seems the download speed increases immediately but it can take a few days stable connection for the up speed to change
Message 3 of 3
solved, there was a cap at BT end.
