stephen1982
Message 1 of 6
has bt reduced fibre speeds?
hi have been getting around 300 to 330 meg download speed the last few months and around 50 up but now when i do a speed test it is now only giving me 92.2 megs down is bt reducing the speeds at the moment? i am paying extra for my connection if they are i think they should tell you
5 REPLIES 5
pippincp
Message 2 of 6
Re: has bt reduced fibre speeds?
BT haven't reduced speeds. Is this G.Fast or FTTP?
If G.Fast check for a dial tone on your line and then for noise. 17070 option 2, best with corded phone.
stephen1982
Message 3 of 6
it is fttp wbc fttp 330 down 50 up it has an active ont and another one can be ordered
pippincp
Message 4 of 6
Ring the FTTP team on 0800 587 4787.
stephen1982
Message 5 of 6
ok thanks are bt back doing home visits now as long as you are social distancing?but if i am correct i f i have an ont they can remote upgrade me aswell if available remotely ?
pippincp
Message 6 of 6
They are doing home visits again. The FTTP team will take care of you if you wish to upgrade.
