Message 1 of 2
high noise margin?
Hi
I have a noise margin of 15.2 dB / 13.1 dB and a line attenuation of 10.6 dB. What does this mean? I'm reading that the noise margin should be much lower at around 3dB. Does this cause interference? online gaming lag?
1 REPLY 1
Message 2 of 2
Re: high noise margin?
High noise margin on its own does not mean a lot as could be due to connection speed lower than attainable as you are on 55mb package
you need to post stats. If hh6 then advanced settings then technical log information
try dialing 17070 option 2. Should be silent and best with corded phone
