jonew
Message 1 of 8
high ping between pc and router
Anyone no why I would get high spikes between pc and router?
Avg is 7ms but it often it spikes to 147ms.
I doesnt really effect much in the ways of downloading but it does cause lag in online gaming.
Can I just plug into modem instead ?
Thnks
7 REPLIES 7
Message 2 of 8
Re: high ping between pc and router
are you using ADSL or Infinity
jonew
Message 3 of 8
Infinity
Message 4 of 8
yes you can connect directly to the modem but you will need to set up a pppoe dialler connection
jonew
Message 5 of 8
**bleep** no idea how to do that lol.
What can be causing this spike?
I heard the hh3 takes packets to test but is hardly noticeable if your streaming etc but can cause lag.
Im really annoyed with it now, I have fibre optic 58mb so I didnt expect this much lag whilst gaming.
Message 6 of 8
go to network settings the select set up a dial up connection also how are you connecting your devices to the hub wired or wireless connection
jonew
Message 7 of 8
Ive tried wired n wireless with no improvement, its sporadic so last night was real bad for gaming but the night before was ok...
Im on option 2 with no caps or throttling (so they tell me) ..
I do have a new house phone which I will disconnect tonight to see if that is causing the high ping..
Apart from that everything is off thats connected to the hh3.
UrbanGrunt
Expert
Message 8 of 8
Step 1: Remove the homehub from the modem
Step2: Connect your pc/laptop into the modem using LAN1 port (LAN2 is disabled and not in use)
Step3: Open network and sharing centre on windows and click set up a new connection or network
Step4:  Connect to the internet (the top option) then click make a new connection Broadband PPPoE
Step5:  Username Internet@btbroadband.com and the password as broadband
Step6: press connect, it may say that it cannot connect, just keep pressing try again if this happens and it will eventually connect.
