Seaking
Message 11 of 12
Re: home hub 3
Thanks very much guys for the help I've decided to go to currys and get the TP Link TD-W9980 lol
It's a bit more from anywhere else but it's only a 10 min drive so I should be up and working when I finish work later on tonight
Thanks again guys
Message 12 of 12
Re: home hub 3
Its a doddle to set up, just set the Operation mode to xDSL Modem Router Mode, select BT VDSL as provider in the Quick Setup, username homehub@btbroadband.com password bt and that's it done. Check firmware is latest 150507, download from here if it isn't.
