hi folks recently as per a previous thread ive had awful trouble with drops and flapping broadband, all cables replaced fibre couplings replaced, so starting to think it might be the smart hub 2 thats gonig faulty.
getting a lot of SIP WAN DOWN and device disconnects.
reading online these can be symptoms of a faulty hub.
can anyone advise if this is indeed a possibility? as no one has offered it as a potential reason as yet from the BT side
Easiest way is to just replace it with one from Ebay, Gumtree or Facebook Marketplace. If it cures the problem you can seek a replacement from BT. If not, then you've eliminated it. You can then either resell it or keep it as a spare.
If you do swap it, make sure you swap the PSU as well.
