Message 1 of 2
how to tell if a smart hub 2 is going faulty
hi folks recently as per a previous thread ive had awful trouble with drops and flapping broadband, all cables replaced fibre couplings replaced, so starting to think it might be the smart hub 2 thats gonig faulty.
getting a lot of SIP WAN DOWN and device disconnects.
reading online these can be symptoms of a faulty hub.
can anyone advise if this is indeed a possibility? as no one has offered it as a potential reason as yet from the BT side
1 REPLY 1
Message 2 of 2
Re: how to tell if a smart hub 2 is going faulty
Easiest way is to just replace it with one from Ebay, Gumtree or Facebook Marketplace. If it cures the problem you can seek a replacement from BT. If not, then you've eliminated it. You can then either resell it or keep it as a spare.
If you do swap it, make sure you swap the PSU as well.
