lenmeadows
Message 1 of 11
http://62.6.38.125/index.html
I have tried to connect to the internet this morning and keep being directed to this page. I have recently changed lines from my business to home line and have been using the same router and had no problems. I have spoken to bt and they seem to think its the router not being a home hub, but I connected the new business hub they sent me when I switched over and got 20 seconds of internet use, before being redirected to this page again, I have seen a different post with someone having the same problem and it being something to do with RADIUS I do not know about this but the call centre staff do not seem to know the problem either
10 REPLIES 10
Moderator
Moderator
Message 2 of 11
Re: http://62.6.38.125/index.html
Hi LenMeadows
Welcome to the forum.
This is quite unique, have you received a Home hub and given it a go?
Send me an email using the contact us form in my profile you can find it in the section 'About Me'.
Stuart
lenmeadows
Message 3 of 11
No I havent recieved a home hub they told me on the phone before that they will send one out. But I have since tried the latest router they have sent and it let me use the internet for about 20 seconds and then stopped, they also told me to use bt wifi in the meantime but my router is not giving off a bt wifi signal
Distinguished Guru
Message 4 of 11
They probably meant for you to try to piggyback on someone else's BTWifi signal.  But that assumes there is one in range.
Is the username in your current router set to "bthomehub@btbroadband.com"?  If not, try changing it.
Aratark
Message 5 of 11
That page comes up if the radius server doesn't recognise the log in details.  It directs you to that page.  What router are you using and what login details do you have in there?  If you have no custom configuration on there, you could try a factory reset of the router and re-enter the residential login details.
Did you change the details on your router from the business log-in details when you swapped to a residential service?  If you hadn't, it may be that the profile has now changed to not allow you to login jusing business details anymore.  That should require you to just out the residential details in.
Edit:
If you could run a quick check for me please.  Disconnect the dsl cable from the business hub and do a factory reset.  Before connecting the hub up, go to the router gui on 192.168.1.254, and if it is the hub3, on the front page of the router, it will show your login details, which will likely be green-light@service.btclick.com.  Reconnect the dsl cable, staying on that page, use the web for the 20 or so seconds you will get and when you start to get this page again, refresh the router page and see if you are getting a user name along the lines of A615273@hg4.btclick.com.  If you are, they are business line details, and your profile is likely no longer set up to get access on them.
Should then just be a case of swapping the user details to the residential ones, which one of the knowledgeable folk on here would be able to advise you of.
lenmeadows
Message 6 of 11
I think this is exactly my problem
lenmeadows
Message 7 of 11
How do I get my home details?
Message 8 of 11
I think this is the details you will need to set it up:  the username needed is bthomehub@btbroadband.com  Password BT will work. It needs to be a PPPoE setting.
lenmeadows
Message 9 of 11
Thanks alot problem solved!
Message 10 of 11
glad all is now solved an interesting problem
