Message 11 of 12
Re: https://pbtcsc.saas.nokia - Hub Smart Speed Test
I'm simply trying to discover if any other BT customers have experienced the same issue and if was resolved.
Message 12 of 12
I'm simply trying to attack the problem from a different angle.
I'm specifically trying to discover if any other BT customers have  had issues with a "PPP Stall" in the past, as customer support have advised me that it is a known issue.
More to point, I am trying to find out exactly what this means and what remedy is required, to correct it.
It is obvious that you can't help, so it's not clear why you are giving me so much grief.
