Message 1 of 6
hub 6 fine for 12 months. Cutting out. Line does not seem noisy
Product name:
BT Hub 6A
Serial number:
Firmware version:
SG4B1000B540
Firmware updated:
23-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 2 Hours 13 Minutes 10 Seconds
Data rate:
4.50 Mbps / 26.89 Mbps
Maximum data rate:
4507 / 28734
Noise margin:
6.5 dB / 4.2 dB
Line attenuation:
27 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
13 MB Uploaded / 75 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-8X92
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
Hub6-8X92-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
B8:D9:4D:26:B4:CB
Software variant:
Boot loader:
7.33.1
Sample of PPP eventd from the log:
14:20:24, 27 Sep.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
14:20:23, 27 Sep.
ppp1:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
15:59:43, 26 Sep.
15:59:03, 26 Sep.
15:58:52, 26 Sep.
10:19:48, 26 Sep.
10:18:59, 26 Sep.
21:42:10, 25 Sep.
21:41:59, 25 Sep.
18:27:25, 25 Sep.
10:34:18, 25 Sep.
10:34:11, 25 Sep.
07:13:09, 25 Sep.
17:48:50, 21 Sep.
00:02:00, 01 Jan.
ppp1:PPP: PPP INFO 217.32.171.22,213.120.234.42
00:01:50, 01 Jan.
ppp1:PPP: PPP INF
Tags (1)
5 REPLIES 5
Message 2 of 6
Re: hub 6 fine for 12 months. Cutting out. Line does not seem noisy
can you connect to test socket with a filter and see if that helps your stability
Message 3 of 6
Good idea.
Tried that and network down again today.
All ideas much appreciated!
BT engineer applied Interleave, Lost 20% speed but no stability improvement.
Toured the overhead line. Seems ok apart from one very tall hedge!
MODERATOR help would be appreciated as have had enough hanging on the end of a line.... life is to short.
Sage
Message 4 of 6
What do you mean by "line does not seem noisy"?
Message 5 of 6
Did the line test as suggested elsewhere using the BT phone number. Kept it going for a while. Slight hiss. No clicks. Seemed quiet. But then I'm not an expert!
Message 6 of 6
the quiet line test sould be silent with a corded phone so any noise is a problem and needs to be reported to 151 as a phone fault not broadband
